360 swap into 65 Valiant ( Need source for oil pan and pickup)
CORRECT! The front corners of a Moroso pan will not clear the K-member of an early A-body. The front corners need to be trimmed off and a small notch towards the rear of the pan is needed to clear the V-8 steering center link (or it will hit the pan when turning hard left). Sorry for the slow response but, I'll try to get you some measurements tonight.
Thanks
Here's the two other pans I have. The greasy one is the 68 340 pan
