SRT_DSTRHOLC
"There is never enough horsepower...."
but it says unported heads
It is a stock eliminator car...they are racing engines with stock parts...chasis are very effiecent..
and a stock eliminator engine is not cheap...a set of heads done for stock small block cost around 3000 dollars by a guy name don little out here on the west coast.
alot of work...and work...
stroked those are some good numbers care to give your setup on the 416
Sorry, I shouldn't have been sarcastic. But, you will always have the extra inches, no matter how much the 360 or 408 is scienced out.I think it's the 48 extra cubic inches.
Also, just for those that may not be aware, NHRA and IHRA Stock Eliminator have different rules than IHRA Crate Motor. "Stock" intakes and stock lift w/ any duration cams in Stock. "Stock" heads in Stockers, too. I was a NHRA Stock Elim racer for a while, I'm not familiar w/ Crate rules. Maybe Myron can fill us in some.
so your motor only makes 320? or you say it makes 320?
planning to go aug 15&16 to bracket bash at greenfield dragway if weather is good lots of rain here engine in sounds really good .No road test yet to much rain
