dart67 FABO Gold Member FABO Gold Member Joined Nov 28, 2004 Messages 490 Reaction score 4 Location NH Jul 10, 2011 #1 To put a 72 360 truck engine in a 73 dart i have to change the oil pan and pick up? Thanks
abodyjoe Well-Known Member Joined May 22, 2004 Messages 24,390 Reaction score 13,756 Location Berlin,N.J. 08009 Jul 10, 2011 #2 yes motor mounts too.
Snake Mopar Nut Joined May 22, 2006 Messages 9,452 Reaction score 489 Location Belleville Canada Jul 10, 2011 #3 dart67 said: To put a 72 360 truck engine in a 73 dart i have to change the oil pan and pick up? Thanks Click to expand... The left engine mount will need some work unless you get aftermarket ones.You must get a center sump pan for sure 360 only.
swinger340 Well-Known Member Joined Jul 25, 2010 Messages 2,273 Reaction score 61 Location Maine Jul 10, 2011 #4 Dont forget the correct external balanced converter or flywheel. Many vibrations caused by using the wrong converter.
dart67 FABO Gold Member FABO Gold Member Joined Nov 28, 2004 Messages 490 Reaction score 4 Location NH Jul 10, 2011 #5 I'm going to get the engine and trans so i won't have that problem thanks
