For my 88 jeep wrangler that sees some road driving in the summer. I need it to idle with a fair amount of vacuum. I want it to sound throaty/raspy/mean at idle though. Current cam is a CompCam http://www.summitracing.com/parts/CCA-20-222-3/
360LA block out of a 78 magnum
Heads are out of a 88 w150 truck w/ some porting done
Speed Pro flat top pistons with 5cc valve cuts
73cc heads (not sure if they have been decked)
Estimate compression would be 9.8:1 or higher
Stall speed is 2-2,500rpm
Edelbrock 28155 MPI single plane intake good from 3,500-8,500rpm
Megasquirt computer management
MSD 6AL w/ blaster coil and stock distributor
tf-727 trans with stage 3 B&M shift kit
4.56 gears with 35" tires
At the moment I have it rev limited to 5,500rpm but would feel safe going to 6,000.
I called CompCams and they recommend a custom grind. Hyd. lifters.
Grind Number 5086-5105H112+4 Lift 520 In: 224 exh: 231 1.6rocker
I would purchase some roller tipped rockers.
I was going to call crower but they are out to launch Any other recommendations?
thanks,
Kirk
thanks,
Kirk
