361 on craigslist for 50 bucks.
  • Thread starter Thread starter JR
  • Start date Start date
Useless. Worth about as much as a 350rb, 413 or 426 wedge. No piston availability. Small bore sizes. Yeah, they can be done but at a huge expense.
Same engine as a 383 except for the smaller bore. Steel crank alone ought to be worth $50, I think. A plus would be a 4 bbl intake as you can use it on a 383 or 400 also.
Dallas
missourimopar.com
Thats an industrial engine, look at the heads. The crank will definetly be steel but being it is an industrial engine it could be an 8 bolt crank. The crank and rods woul be about the only thing useable on a car engine, well maybe the pan also. Being it is a '61 the crank hole might not be big enough for a later model convertor without machining it.
Chuck
