MOPARJ
What can I upgrade now?
I know its not an Abody, but its a Pentastar and you guys have always come through with good tech opinions and advise for me to compare my diagnosis' with.
I have a 66 Charger with a 361 that I acquired for my father. The car sat motionless for 17 years, but started fine and ran on all 8 cylinders with no smoke, until today. I have had it for 5 months and it has not been driven, just fired up and ran once a week for 25 minutes or so at varied rpms.
I went to fire it up today, and I noticed a slight misfire, almost like a dead cylinder or loss of compression. The real issue is the extensive and contant blue oil smoke puffing out of the rigth cylinder banks tailpipe. I am at a loss. How the hell could this happen so suddenly? It was running fine, with no smoke for 45 minutes yesterday. I checked the right banks plugs and they had some oil on them, but not a large amount to signify the problem has been present for a long time. Nothing was severly fouled.
Does this seem too sudden for a ring land or ring itself to fall apart at startup and cause this problem, or possibly a valve seal? I wouldnt think a valve seal would cause consistant smoking and a misfire. The smoking gets worse with rpm it seems. I replaced the pcv to no avail. Am I overlooking something?
I have yet to run a compression test. The oil has a slight fuelish scent, but not like pure fuel. This is due to the slightly maladjusted carb. I wouldnt think that a ring would wash out that quickly. The oil had no milk in it, or other signs that would hint at a cracked head or head gasket.
Any advise or opinions are appreciated.
