380 HP Crate 360 Camshaft
72DMag
Pittsburgh
Hi does any cam manufacturer offer a remake of the 380 hp crate engine 360 camshaft?? The part number is P4876348??
It looks like this camshaft has not been made for some time now. But for a build I am doing it would be perfect to use with the stock rockers given its large duration and smaller valve lift.
is that an hr
specs
shaft or magnum rockers
stock as in stamped steel or iron
severalpeople have replaced that cam
Google is your friend I was studding these when doing my 5.9 build there are several out there that's very close I had Oregon cams grind one to their specs I'm sure they could duplicate the oem one
@dodge71demon Was the custom grind expensive? That would be the way for me to go. I have searched summit racing's cam options up and down and I couldn't find a cam that has that much duration with that lift.
I think in the 325 to 350 range got the long nose didn't need it but something about had to get a billet one
Call jim at Racer Brown and tell him what you want. A custom cam is cheap money. I think mine was 185 bucks. Why skimp there?
I'd would just go with another .500 lift cam, especially if its mainly a street car mines soft under 2500 rpm. A milder cam would get you 90% of the peak power and keep the bottom end. If not just go with one of the thumper cams pretty similar to the create cam.
what's the lift limit?
crap the thumper is nothing like the crate cam
just look at the intake exhaust spread
otherwise u are correct
why are people replacing the crate mptor is what I would like to know b 4 Making one
Cam specs for the P4876913 & *P4876906 are
0.501 intake duration 230 @.050 288 Mopar degrees 294/298 comp degrees
0.513 exhaust duration 234 @ .050" 292 MOPAR degrees 302/306 crane degrees
it is a VERY lumpy cam that has low engine vacuum\
P4876348 is the same with a 108 "centerline"
now is that ICL ot LCA?
P7007547 380 upgrade 280/288 542/552
Typically, 360/380hp owners wind up putting a milder cam in
you want the best hr lobes contact mike jones for his inverse flank designs
