[Found!] 383 block
I've got a C383 non-HP block - not sure on the month of casting but it's a '67 model assembly.
Non HP block that is fine. Just need date code to be 8th or 9th month in 67 . When you check let me know. Thanks
I checked and mine is cast in 2 of '66. Was probably a wild goose chase anyway because if you need a late 67 block you need a D383...
