WARLOCKII
We recently installed Edelbrock E Street heads and Mancini roller rockers on our 71 383. The rockers were set to .025 side clearance as recommended and zero lash plus half a turn. We have adjusted the lash 3 times and still have lifter noise. Is it possible the spring pressure on the new heads is causing the lifters to bleed off? We are running a Comp Cams 268H, hydraulic flat tappet lifters (I don't remember the brand, not Comp). The engine carries 60psi cold and 40psi hot oil pressure. I don't believe we have wiped a cam lobe but don't want to either. Any ideas or suggestions would be greatly appreciated. Thanks
