383 Manifold casting numbers
Golden Scamp
Topeka
Will casting numbers make a difference on whether manifolds will fit a motor? I'm looking at a set of 68 manifolds - #2535484 # 2461307 - for my 68 Dart, which is currently a slant 6. I will be dropping in a 1970 383. Would these 68 manifolds fit the 70 motor, which is a totally stock 2 bbl motor. If more info is needed, please ask so I can help you help me. ThanksView attachment 3G13I53L35Nd5Gd5K9d33242fa89cbea21b05.jpg
How about casting numbers 2806900 and 2806974. I think these are 1968 HP 440 manifolds. Would they bolt up to the 1970 906 heads on my 383 plus give clearance for power steering pump in 68 Dart? Will have Shumacher mounts to convert six to eight and would like to avoid headers if possible for factory look. Hyperlink above shows this to work but want to make sure these manifolds will bolt up. I think yes because of same heads, but need advice.View attachment $T2eC16R,!ysE9sy0iIGeBR(lEtoFh!~~60_57.jpg
Yep Andy, those will work. That's what I picked up for my swap. I am saving some cash to rebuild a '69 383 I have. The plan is the same as yours, I want a factory look on my '75 Scamp.
