383 needs more power
Magnum Engine Swaps
  1. 71duster383
    71duster383 Member
    9
    3
    Nov 9, 2018
    Canada
    Local Time:
    9:48 PM
    In October’s I purchased a 1971 Duster with a 383 and 727 auto. In the spring I had the car dyno’d and it made 230hp/286ft lb at the wheels. I feel these numbers are lower than they should be. I have a 750 demon carb, Edelbrock dual plane RPM intake, headers, XE284H Comp Cam. Unsure of what heads are on it. Any ideas on what I can do to spruce it up a bit?
  2. Fisher
    Fisher Old Guy with a Cool car.
    1,881
    833
    Jul 22, 2012
    Regina Sask Canada
    Local Time:
    10:48 PM
    About all you can do is change the cam to something with more lift, thats a pretty small cam anyway. and either port the heads you have or buy a decent set of aftermarket aluminum. Does this motor have headers on it now? What is your main use of this car?
    I took a 383 machined in a 440 crank = 426 now. Makes 525 hp and 552 tq. Nice street manners, drives well no complaints.
  3. dano
    dano Evil Handy Man
    2,805
    803
    Aug 22, 2005
    Gresham, Oregon
    Local Time:
    8:48 PM
    The thing about dyno's is they are a tuning tool. You could drive down the street to a different dyno and gain 50hp, or loose 20.
    Was any tuning done to achieve your output?
    Tell us more about your combo. What is the static timing and total timing at what RPM? What ignition system are you using? Have you looked at the plugs to see if you lean or rich? Was the engine rebuilt?
    • Like Like x 1
    • Oldiron440
      Oldiron440 Well-Known Member
      447
      482
      Jan 12, 2019
      North central Iowa
      Local Time:
      10:48 PM
      When on the dyno did they tune the carb and timing?
    • 318willrun
      318willrun Roadkill '80 D150
      13,469
      13616
      Sep 13, 2013
      I'm here
      Local Time:
      10:48 PM
      First post since 2018? Welcome to the site! I would try tuning what you have. I would start with this list:
      1. make sure throttle is coming open all the way
      2. check initial timing
      3. check total timing
      4. check compression
      5. make sure all cylinders are firing (yes, I've seen a dead plug wire)
      • Like Like x 3
      • Agree Agree x 1
      • 71duster383
        71duster383 Member
        9
        3
        Nov 9, 2018
        Canada
        Local Time:
        9:48 PM
        No tuning was done. I was hoping the tech would spend more time tuning on it but he told me he was too busy and unfortunately is the only local guy with a dyno. Next one is three hours away. Initially timing is 15 and up to 35. I have a MSD 6A ignition system with a MSD pro billet distributor. Engine was rebuilt in 2012 with all new bearings, pistons, rings and bored .040 over. Peak HP is 4450rpm and peak tq is at 3950rpm. A/F ratio was pretty good on the dyno. Just want a good hp street car. It currently has 4.10 gearing and I want to put in some better highway gears but don’t want to lose the cruising around town fun part either.
      • rumblefish360
        rumblefish360 So close, yet so far away FABO Gold Member
        37,382
        9099
        Jun 21, 2005
        New York, on a Island
        Local Time:
        11:48 PM
        Stock heads?
        Small-ish cam?
        I think you could change those two items and pick up some really nice torque and hp numbers.
        Tune tune tune!!!!
        • Agree Agree x 1
        • 71duster383
          71duster383 Member
          9
          3
          Nov 9, 2018
          Canada
          Local Time:
          9:48 PM
          What cam and heads would you suggest?
        • rumblefish360
          37,382
          9099
          Jun 21, 2005
          Local Time:
          11:48 PM
          Trick flow heads.
          If the cams duration (which dictates the RPM band it operates in) is fine with you, just look to more lift.
          You didn’t mention your compression ratio.
          That could be an issue as well.
        • diymirage
          diymirage HP@idle > hondaHP@redline
          17,640
          10914
          Oct 12, 2012
          michigan
          Local Time:
          11:48 PM
          318willrun gave you 4 good tips, which are all free and possibly the awnser to your problem an you go straight to the $4000.00 answer?
          do the simple and free stuff first
          stupid question for you, when you pop your hood, is the distributor on the front or on the rear of the engine?
          • Agree Agree x 1
          • RustyRatRod
            RustyRatRod Weenie idiot loser. FABO Gold Member
            58,461
            28838
            Jun 7, 2010
            Georgia
            Local Time:
            11:48 PM
            He's talking about this camshaft.
            11-651-47 - XTREME Energy™ Hydraulic Flat Tappet Camshafts with 18736542 Firing Order 4 & 7 swap firing order.
            Hardly low lift for a hydraulic flat camshaft. That's a stout camshaft for a stock stroke 383. Which is what we're talkin about here, not a stroker. Apples to oranges and does the OP no good. Lets keep the discussion down to what he HAS so we can better help him. Ok?
            To the OP, first off, how does the car RUN? I mean omitting anything you have learned dyno wise? Are you happy with it? Will it smoke tires? Does it accelerate briskly? It may well be fine, because it's possible to lose 100 HP through the drive train.
            That said, here's where "I" recommend starting. First, run a compression test and post up the numbers. This will give us a good idea about the static and dynamic compression ratios of the engine. My guess is, it will be 120 or less. We can better advise you with compression test numbers so get crackin and let us know.
            You have lots of options. You can taylor the camshaft timing to better match the initial cylinder pressure readings. If they are low, you can advance the camshaft timing. If that engine has stock compression pistons in it, I would put that cam somewhere around 100-102 ICL. But that's getting ahead of ourselves. Lets get those compression test numbers first and we can go from there, ok?
            • Agree Agree x 2
            • RustyRatRod
              58,461
              28838
              Jun 7, 2010
              Georgia
              Local Time:
              11:48 PM
              Exactly.
              But no! Lets throw heads and a stroker crank on! geez.
            • dano
              dano Evil Handy Man
              2,805
              803
              Aug 22, 2005
              Gresham, Oregon
              Local Time:
              8:48 PM
            • RustyRatRod
              58,461
              28838
              Jun 7, 2010
              Georgia
              Local Time:
              11:48 PM
              Oh ok, I posted the wrong one then. Still though not a small cam for a street non stroked 383.
              • Agree Agree x 3
              • rumblefish360
                37,382
                9099
                Jun 21, 2005
                Local Time:
                11:48 PM
                That should be a healthy power maker. IDK what others think, low .500’s is low lift IMO.
                Honestly I thought it was the next smaller grind.
                My bad, but still hold my stance.
                First thing is first, tune tune tune.
                Visit the track and get the distributor and carb dialed in and see what you get before and after. You might end up happy.
              • RustyRatRod
                58,461
                28838
                Jun 7, 2010
                Georgia
                Local Time:
                11:48 PM
                I agree with low lift, but overall, it's a sizeable camshaft for a stock stroke 383.
                • Agree Agree x 2
                • 71duster383
                  71duster383 Member
                  9
                  3
                  Nov 9, 2018
                  Canada
                  Local Time:
                  9:48 PM
                  Thank you for the direction! It runs really well and I am happy with it right now. It’ll smoke the tires pretty good and snap you back in your seat. But like I said earlier I am hoping to swap the gearing from the 4.10s to something a little more highway drivable but I am worried I will lose the tire smoking ability. I also feel that the numbers are a bit low even for a completely stock 383. I believe a stock 383 is 335 hp at the crank from factory. With the little bit of work that is done to mine, the 230hp at the wheels equates to about the 280hp mark at the crank. (Using 17% drivetrain loss) so I think the power should be available in my engine. It just needs to be brought out. I will get the compression numbers and let you guys know. Thanks for the help. This is my first muscle car and am loving it. Just have lots to learn.
                  • Agree Agree x 1
                  • rumblefish360
                    37,382
                    9099
                    Jun 21, 2005
                    Local Time:
                    11:48 PM
                    Ehhh, that figure (hp), was it for the hot engine package or the standard engine package? I forget.
                    The compression could be low and the reason.
                  • RustyRatRod
                    58,461
                    28838
                    Jun 7, 2010
                    Georgia
                    Local Time:
                    11:48 PM
                    Then to hell with what that dyno says. Dynos are like opinions and we all know what those are like. Another dyno might give you a 100 HP difference. Either way. It depends on the dyno somewhat, but moreover, depends on the skill or lack thereof of the person operating it. So take it with a grain of sand.
                    Also, if it smokes tires now, changing to a numerical lower gear set like a 3.55 (puke) will make it smoke tires more, because the tires will be turning more RPM.
                    Again, don't take stock in those dyno numbers. They are just that. numbers. Not performance. et us those compression numbers and we might can help more.
                    • Agree Agree x 1
                    • diymirage
                      17,640
                      10914
                      Oct 12, 2012
                      michigan
                      Local Time:
                      11:48 PM
                      post a pic of the engine
                      (I still want to know where the distributor sits)
                    • 71duster383
                      71duster383 Member
                      9
                      3
                      Nov 9, 2018
                      Canada
                      Local Time:
                      9:48 PM
                      It sits at the front of the engine. E01A1BB3-0447-40D6-8A3C-3123789BA81D.jpeg
                      • Like Like x 1
                      • diymirage
                        17,640
                        10914
                        Oct 12, 2012
                        michigan
                        Local Time:
                        11:48 PM
                        awesome
                        that means you got the big block, but posted your question in the small block magnum section of our forum (I was afraid maybe you did have a magnum, in which case the HP numbers weren't unacceptable)
                        don't freak out if this thread disappears, one of our moderators is bound to move it to our big block section:
                        Big Block A body Tech
                      • 71duster383
                        71duster383 Member
                        9
                        3
                        Nov 9, 2018
                        Canada
                        Local Time:
                        9:48 PM
                        Oh shoot! Sorry about that my bad. Ya it’s defiantly a big block.
                      • R4Sedan
                        R4Sedan Forum H/R Dept. President FABO Gold Member
                        4,720
                        1989
                        Nov 26, 2009
                        Tampa, Fl
                        Local Time:
                        11:48 PM
                        Finally, someone knows how to talk gears. Numbers go down it's LOW they go Up it's geared HI.
                      • 383Scampman
                        383Scampman Well-Known Member
                        1,543
                        777
                        Nov 24, 2013
                        New Hampshire
                        Local Time:
                        11:48 PM
                        320hp at the tire is a good combo . As was posted before : tune, tune , tune . I have a 383 Scamp and would be very happy with it .
