390 stroker
w7smallblock
pennsylvania
Rating - 0%
0   0   0
390 stroker only 400 miles since built has run 11.78 in a 3600lb street car with 3.73 gears on pump gas.
A run down of the motor (note motor does NOT come with carb,dist,or valve covers in picture will replace with factory covers)
late 80's 318 roller block bored .030 and deck set all machine work was done by shady dell.
LD 340 intake
Indy RHS X heads
PRW 1.6 stainless roller rockers
custom 5/16 TREND push rods
Johnson factory replacement roller lifters
New spider and dog bones
Bullet custom billet roller 516/516 237/241 @.050 on 109LSA in at 104
Liberty 9 key way true roller chain and tensioner
Icon IC847 dished forged pistons
Scat 4340 I beam rods
Mopar performance 4.00 cast crank (bottom end is internally balanced)
Pioneer dampner
Kevco oil pan
Motor is still in car will NOT be pulled until sold. Will not ship
price $4200 OBO (will sell carb ,headers and dist with motor at extra cost)
Motor is located in Hyndman Pa
400 miles...That's a lot of passes!
So, how many passes on it?
When was it built?
Why are you getting rid of it?
Oh, was that on slicks or DOTs?
I'm assuming with these pistons (and that much cam)this runs pump gas with no issues..
Sounds like a fun Street and Strip engine! :burnout:
This is a street car most miles are on the street. I would have to count the time slips probably about 30 passes was to the track 3 times with it. I built the motor this summer. I'm selling because i'm putting my 408 in the car that I was building for a car that I sold. The 408 should make 85-100 hp more thats why the change. A 275/60/15 M/T E/T street radial was on the car. The car runs fine on pump gas thats all thats ever been in it. It only has 9.46:1 measured comp and the cam is not that big for a stroker..
