[Found!] 4 Barrel Carb Kick-down Lever
dart_man440
Mopar 4 Life
Arizona
Hello everyone, am helping a friend of mine with his project and noticed that he doesn't have the correct 4 Barrel Carb Kick-down Lever. (It's for a SB the one from the carb to the butterfy). Please let me know if you have one you can spare. Thank you,
So people know what you are talking about.
Like this?
The first one you pictured is from a later f-body. It will work. The second one is from and E-body or 71 up B-body . That is a one piece rod and will not work on an A-body. You need three piece linkage due to the firewall being close. The orange is 340 727 4bbl. The blue is 904 318 2bbl. Notice the rod that goes to the carb is threaded for adjustment on both. The 904 F-bodies 4bbl's are not. The rod will work but note the lever and lower rod is different. Also clocked different. I use them but you will need to get the geometry right so they stay eye to eye Carb and trans . I included a picture of a 4bbl in a Duster with a 904 using the F-body 4bbl rod and linkage. It is used with a 904 trans and lever.
That’s what I call helping someone out, not criticizing! Thank you Olmanmopar!
Thank you all for your help. Please see attached picture for the lever I need. I should have been a little more specific in what I needed. I only need the lever and the butterfly, I have everything else to help my friend. If you have a comment not conducive to my post, please be respectful and keep it to yourself or PM me and we can discuss, if you are looking for the same item be respectful and post your own wanted add. Admin, thank you for helping with the hijacker post, if you see anything wrong with this post please let me know. Thank you,
Hello everyone, still looking if you can help!
Just got home I will post a pic of my stuff in a few minutes
