4 barrel carb on slant six 1973 plymouth duster
Efregoso
Member
Chula Vista
Hey, so I am working on building a 73 plymouth duster, currently it has a slant six 3.7 with a single barrel carb. I am looking to put a 4 barrel carb on it. I know I would have to use an adapter just wondering which one would work
Offenhauser, Clifford, Weiand and Aussie Speed parts all make 4 barrel intake manifolds.
Well, Weiand USED to. They are hard to find now.
Talk to "805moparkid", he races one pretty regularly & can help you along with a /6 project.
Hey thanks I am looking to get an edelbrock 450 cfm just this is my first build so I'm trying to figure out it will work, and what adapter plate I would need
on a / 6 stock cam a 4 bbl wont do a lot. cause the cam will not pull enough to make a 4 bbl work. but a 2 bbl 318 carb really works. and the swap i did didnt need tuned.
Don't waste your time and money with an adapter plate. If you really want a 4bbl carb on the slant six, use a 4bbl manifold. They are available new, or used.
