[Found!] 4 barrel kick-down rod (between carb and throttle bracket)
Calipag
Corona California
Looking for this kick down link or a part number or where to buy one. It's for our 1970 Dart 318, with an Edelbrock LD4B, and an Edelbrock 1406 carb- just like the photo below.
I just made my own last week. Took a piece of 5/16 mild steel bar and fabbed it. Working perfect. I’ll send a pic tomorrow. Less than two hours.
Can you use all-thread and lock-tite with a barrel nut?
(or a barrel nut and jamb nuts)
That's if you don't have access to a welder to weld on the all-thread as an extension.
No, The member thought he had the correct part and shipped it to me. But it ended up being the wrong part.
So I am in need of the 4 barrel kick down rod like the one in the picture.
Thank you.
Thank you.
You need the original 2 barrel rod and a extension made for a 4 barrel modification. Here's some kickdown parts for sale. [FOR SALE] - Misc.parts...
Here's a thread with the info for some other parts. I will look up the kickdown adapter. 2-Barrel to 4-Barrel Conversion
Here is the link to the kickdown adapter:2-Barrel to 4-Barrel Conversion
Thank you.
I have searched the few conversion threads and have even PM a member about the conversion. There is no part number for just that 1 rod and the entire kit is a bit expensive. I may do as others have and make my own. Thank you for the links.
Thank you.
You bet!
