4-BBL carb orientation?
halfafish
Damn those rabbits, and their holes!
SW Washington
I'm putting a small 4-BBL carb on my slant. The carb is an Edelbrock AVS500, the intake is a Clifford. My thought was the carb should be oriented with the smaller primaries facing either towards or away from the head. It seems to me, that would allow more even and balanced fuel flow down the intake runners.
However, as I fiddled with the carb and which way it should go for best performance and throttle/choke cable access, it becomes apparent the mounting base pad on the intake is angled towards the front of the car. Why is this, and does that have anything to do with how the carb should sit?
For those who have been down this path, I'd be very much interested to see what you did for this situation, and how you liked your choice.
It's been dyno proven that it makes no difference whatsoever. I just put mine on the easiest way. It hauls ***.
That angle is because the engine is angled front to back.
With the angle on the manifold, the carb sits level.
Aha, I was unaware of that - thanks!
No sir, no auto for this guy. It has a 4-speed OD.
Well! In that case when I clocked that carb primaries towards the valve cover I noticed better low end throttle response!
