4 SPEED INTERCHANGE QUESTION
CFD244
"THE NEW OLDSMOBILES ARE IN EARLY THIS YEAR"
Northern Ontario, Canada
Hi Folks
I have a 3 speed manual transmission with bell housing, clutch, pressure plate and flywheel from a 1971 318 Demon. I also have a 4 speed manual transmission with bell housing, clutch, pressure plate and flywheel from a 1970 340 Swinger.
My question........Will all of these parts play well with each other. That is, can I arbitrarily mix and match the two sets of components I mentioned above?
Thanks FABO
I do believe you can . If my memory serves me the bellhousing has two patterns for the trans that allows for either 3 or 4 speeds. Over 20 years ago I switched over to 4 spd from a factory 3 spd and used the same flywheel, clutch, bellhouse, throw bearing etc. Even the drive shaft. Trans and shifter were the only things swapped out. Again that is what I recall. This was on a factory 340 3 spd car. Others might chime in and refresh my memory.
Your bellhousing should look like this if you're going to use it with a four speed. Just pulled this one yesterday from my 70 318 three speed.
