[SOLD] 4 Speed OD Aluminum Case Transmission
bradfields
Indiana
The shifter, rods, etc. have sold, I still have the transmission for sale, there is no speedometer housing or gear.
$200.00 plus shipping from Indiana - zip 47872
Will this bolt up to the small block mopar bell housing or was this one of the ones that had the GM pattern?
That's a Chrysler truck a833OD. Yes, it will bolt right to a small block bellhousing.
It will depend on which small block bellhousing. The input bearing retainer is slightly bigger then a regular A833 transmission. Thanks to Brewers Performance for the information and the measurements to make it fit.
I was assuming everybody knew that. My bad.
