4 speed pedal fix
chrisf
so i got a set of pedals off a guy and they were not as advertised. the pedal stop has been monkey'd with and is a disaster. so my question, is the main pedal frame the same as auto pedals? can i just swap the necessary stuff over to the auto pedals? dumb question but never did a swap like that so curious. i think i have some auto pedals around somewhere.
The only difference I have noticed is the clutch pedal neutral safety switch bracket mount doesn't have a nut welded on the frame from an automatic setup.
There should be an extra bracket to support the outboard end of the clutch pedal....
