[SOLD] 4 speed setup
d55dave
Kelowna, British Columbia
For sale is a 4 speed conversion set up for a second generation (67-76) mopar A body (dart, valiant, duster, demon, barracuda). Included is the bellhousing, lower cover, starter tin (forward cover), OE floor hump, pedals, OE inner fender reinforcement, z bar, pedal to z bar rod, clutch fork, floor shift steering column and hurst shifter box. Also included are two transmissions, the first is a rare all iron (no aluminum case) A body OD 833, the second is an aluminum long tail shaft OD 833. You will need a shifter handle and a few small clips and parts to complete this. All parts will need to be gone through. Local pick up preferred in kelowna British Columbia but I may be able to deliver to Vancouver BC or northern Washington State. Asking 1,800 CDN, 1,350 USD OBO.
To be precise, this is a 1974 A,B, or E body, 10.5" or 11" clutch bellhousing. One trans appears to be from an A-body...the other from a B....
Yes, correct. The bell is a correct A body piece with the 5.125" opening to suit an overdrive or hemi 4 speed. The short transmission is a cast iron A body overdrive 4 seed, the long one is an aluminium case truck / van overdrive 4 speed which could be made to work in an A body.
