4 speed trans hump
bradford
Professional at nothing
N.C
I have a 70 duster and I am converting it to a 4 speed.I need to know where to put the hump at in the floor?I know I can mark it by the transmission but it is out of the car and if I can get the info with out having to put the transmission back in that would be good.Pics or any help would be fine thanks.
well, since i used a original, that was cut out of another car, all i had to do was grind off all the spot welds, and it really almost sits perfectly into place. if you move it aound a little, you will see that it is a no brainer. if you got a reproduction, i cannot help you,sorry
Mine is a original to but when I put it in it just looked like it was way towards the drivers side and I just wanted to make sure thanks for the info.
Cool thanks for the info.This is a great site for someone doing a restoration on a body cars.
