IMHO, I wouldn't be concerned one bit with rod ratio when using most of the current B block stroker kits. Changing the ratio sure won't help or hurt performance in any noticeable way.
If it's a street strip car, find a piston that has at least 1.25-1.3" compression height and get whatever rod length/stroke combo that fits your deck height. Find the lightest piston for the combo too. Sometimes the taller compression height pistons weigh less than a shorter because of the piston blanks that are used.
Full on race car, then the shorter pistons are OK. I still prefer something more stable. The 500" B block uses pistons that look like hockey puck, ~1.122 CH, which have been known to be a bit unstable in the bores.
Building a 512 cu in, 4.25", 6.535 rod, 1.32 piston is not an issue in the B block. Strong proven engine, make sure you have a set of heads to feed it.
And to carry on mopers comment re: 3.915.... You can put together a really strong combo using a 3.915 crank, 6.7 rod and 1.32" CH piston (same piston used in a 451 or 512). It won't be as hard on the block (ratio), stable/taller piston.
