604B1duster
- Joined
- Dec 30, 2007
- Messages
- 1,500
- Reaction score
- 689
I need some advice. I bought a nice used 408 short block with flat tops. Bought a stock set of eddy heads and comp xe294 cam and lifters. I put it together with .100 cometics to get the compression down. It has 1.5 crane rollers. Its almost ready to go in the car. Then later, got a deal on a set of stage 11 ported eddy heads done by Hughes. I am going to swap the heads and want to keep the cam. The springs comp recommends for the xe294 have a seat load of [email protected] and an open load of [email protected] (.550). The springs on the hughes heads are [email protected] and [email protected]. What I need to know is can I leave this cam in the motor, run the ported hughes heads and use a 1.6 rocker to get the lift up to around .550. With the .100 gasket I come up with about 10.9 comp. T ram with two 500 eddy carbs, 3000 stall dynamic and 4.10 gears. Street car . I really want to use what I have, if possible. What do you think ?
