OK, i've got a 413 with stock passenger car flat top pistons. What kind of compression ratio would I get with later 906 heads?
Greg
Pistons are stock 1965 vintage cast flatops. Can't tell you how far down they are. Deck is stock. Heads are stock 70 440. Head gasket is steel.
A "wag" would be helpful as I put this motor together (poorly) in 1979.
Greg
The original heads would have been closed chamber, and I think the true compression would be around 9:1 with a steel shim gasket (advertised around 10:1 I think). So you're going to an open chamber head - it will be closer to 8:1 espcially if you go with a composite gasket.
