Are KrazyKuda's heads stage III heads ?
Bingo! :cheers:
Give that memike a prize! :blob:
Hey ph23vo how can you assume its a street wedge with out me posting the engine and head #s without me posting pics.. I'll post the pad info on Friday to make you a believer
Man, you all act like you ain't ever seen a Max Wedge Head or Intake before.... :crybaby:
no,,,,,.................that is not what i said at all. The op is the one claiming to have a maxie. Why can't he just post a photo or tow. Geezus fawh hreeekin karueuast if i scored one i'd sure as hell be showing it off................................
No,,,,,.................that is not what I said at all. The OP is the one claiming to have a maxie. Why can't he just post a photo or tow. Geezus fawh hreeekin Karueuast if I scored one I'd sure as hell be showing it off................................
The 383 and 426 wedge both have 4.25" bore. Just different stroke 3.375" vs 3.75". Pistons can't be all that rare for that bore size.
That's just it........."max" wedges are NOT that common. There's quite a few 426 lower performance engines, as they were used in trucks and motor homes, and industrial "stuff"
I once saw a guy at Mopar Nats many years ago in Indy (like 86). He had a Max Wedge (Stage II) intake with carbs and linkage for sale asking $1200. I asked him "What would you take for them?".
He replied, "Those are high performance parts, there's no dealing on high performance parts."
As I was leaving, I noticed in his flyer that he was looking for those same series heads that I have. So I wanted to "test" him, and took the flier and asked him what he'd give for a set of 518 heads. He played dumb and asked, "What are those?"
I replied, "The ones in the flier here that you are that you are looking for."
He said, "Oh, I'll give you $500 for them."
I laughed in his face while turning away and said, "Yeah, right...." :finga: :finga: :finga:
$1200 and "no dealing" on an intake, carb, and linkage setup, but my heads are only worth $500.... FLIPPER.... :finga: :finga: :finga:
"You want to suck my what????
Picsi was in the hunt for a big block a few years ago so i answered an add on craigslist and came across a late 1963 426 max wedge with the 6 bolt heads wasnt sure what i had actually purshased untill i got it home and decoded everything yuuup i scored big only paid $350 with the engine stand that it was on ...my plans are to install it into my 70 swinger with a sure grip mini tube and a four speed what do you guys thunk i need to do to the 426 to run mid / hi tens in the 1/4
Pics
518 heads would've been adj rockers I believe and max wedge...these appear to be reg 516 common heads for bblk engines...so it's not a max wedge engine...
Maltese cross indicates it had factory under size bearings somewhere.
