[SOLD] 42RH/46RH Overdrive alignment tool
roadrunninMark
GA
Rating - 0%
0   0   0
I have the alignment tool for the 42rh/46rh overdrive units, might be same for RE versions too. Transmission is done so I don't need it anymore. $85 plus shipping (should fit in medium USPS box). I am in Fayetteville GA for pickup as well. Please message me. Thanks
When you rebuild the overdrive section, all the splines have to be in alignment otherwise you won't get the shaft set into it completely. Think of a clutch alignment tool but for multiple layers that need to be lined up.
