Hello Men,
Looking for some input suggestions- this is it,I picked up a '69 Dart with a 440/4 barrel
750 DP Holley.Very mild cam only 5k on motor since complete rebuild. Was a 4speed but prior owner installed a 727 his/hers hurst on floor.its a '69 block punched 030/906 heads(not milled)
10 1/2:1 flat top pistons. What I want to do is put my '69 1/2 Edlebrock/mopar Aluminum intake 1350 cfm set up. What do you think of this cam? I have it from back in the day new in the box -General Kinetics part #N2M-292-P lift int/ ex 496/521- nom duration 282/292 -Duration @050 224/234 -Lobe lift 310/326 1.6 rockers and a 114 CL. How will this run with an automatic tranny(mild shift kit) will it handle the gas and SOUND GOOD? Pump gas, street car
That can move out (355 rear gears/-8 3/4). If not this cam suggestions???
Thanks for all your time and help, and A HAPPY AND SAFE HOLIDAY SEASON TO ALL
FAMILIES AND MILITARY!!!!!!
Mitch
Mitch
