[WANTED] 440 Crank Pulley
Have a three piece one that lines up, blasted and epoxy painted. 28 shipped.
Is it common to have to need a spacer to get the pulleys to line up?
I'm not to familiar with big blocks and the engine was apart so I don't know how it was originally. I have a double pulley on the water pump so i am assuming that I will have one belt for the water pump to alternator to crank pulley and one for the water pump to power steering to crank pulley.
Am I on the right track?
That's what I have for the same setup. These are from a marine 440 and line up like mine do.
I have a double groove crank pulley. If came off a 440 so it should work without any spacer or modifications. Search Albert19 and Double Groove Crankshaft Pulley. Price is $25 + shipping which would be about $20.
