Kendog 170
Let the boy go !
So I've noticed considerable play turning my rotor back and forth on my 440/500 motor . I pulled the Dizzy and drive gear and it seems the slot on gear is wider than the end of the dizzy . I found a similar thread where someone had the same issue but he never finished the thread. I don't want to resurect it as it is a real old thread . My timing jumps up and down about 4 degrees consistently. I have yet to check for slack in the chain yet but thought I would ask if it has happened to someone here.
Thanks
Thanks
