440 eng.& 727trans.from a Winnabago
shocktrauma
Active Member
milford De.
The 440 is rebuilt & trans but I think My cars trans is geared differtly than the passenger car because it's from a Winnabago (truck) it tacking (RPM) 2100 and my speed is only 50 mph rear end gear ratio is taged 3.23. My question is Are 727's trans. gear differently for trucks and cars and if so don't they both have a final gear drive ratio of 1.1. It's a 73 eng. trans combination... No overdrive.
im fairly sure the trannys are all the same gr its in the rear gears that are lower
