racerx
racerx
Will a 440 fit under the stock flat hood in a 71 duster with the RPM intake? How does the Street Dominator compare with the RPM. Spool-type K-frame with Schumacher mounts and Eddy RPM heads, street/strip 475-500 HP. Comp Cams XE258HL hyd-flat-tappet cam. Holly 800 DP.
