440 source fluid damper
gilstrj
BBDart74
Seneca, SC
My damper makes a sound like something is spinning inside it for just a second after the engine is shutdown is this nomal?
Sounds like a ball bearing style damper, and common to them.
It uses the same concept as those balance balls they put in tires.
None of the 440 Source Dampers I have used have sounded like that. Call 440 Source and ask them, they are easy to deal with.
Fluid type dampeners have nothing to make that noise naturally. Rattle-types do.
