73 Duster_forever 73
Active Member
I’m looking at getting this water pump housing but I don’t know if it will fit I wondering if anyone knows the part number on it.
2780 987
2780 987
Shown above is the most widely used housing, casting #2780987. This housing was used on almost all cars and light trucks from 1967-71, making it the desired housing for nearly all muscle car applications, including 426 Hemis
There are two different castings for the driver side inlet. The difference is the location of the alternator bracket bolt near the thermostat.There is 2 different housings. Lower hose on the left like your as shown by 72duster440 or lower hose on the right. You need the correct damper and timing tab for each one. Kim
my factory hemi pump wasnt like that , was lower pass side...
