#MadMax
Hi thanks for looking. I have 3 complete engines come as pictured as all 3 have air cleaners and clutch fans. The engine stands do not go with engines.
One 440 has 68-69 date code parts that one has b body 68-69 hp exhaust manifolds, has double roll timming chain, new lifters, water pump, and alternator. Stock bore flat top pistons six pack rods and steel crank all balanced together. Cam is a 468 lift torquer cam, comes with a dual snorkel air cleaner and clutch fan. The block has no vin stamping. Block cast numbers are 3698330 casting date 7-2-73
ID pad j440T 7-18 2
Second 440 has Aluminum intake 68-69 c body hp exhaust manifolds, windage tray and oil sling, double roll timming chain, new lifters, water pump and alternator . Stock bore flat top pistons six pack rods and steel crank balanced together. Cam is a 468 lift torquer cam. Comes with air cleaner and clutch fan. This block has no vin stamping. Block casting number 3698330 casting date 1-15-73
ID pad j440T 2-2 2
400 all stock with Aluminum intake, new double roll timing chain, new lifters, water pump, and alternator. The 400 has b/e headers with header bolts. The block has no vin stamping. Block casting number 4006530 casting date 7-27-77
ID pad 7T400 9 8 E
All have electronic distributors with new plugs and wires cap and rotor. new gaskets top to bottom front to back. all have new dip sticks.
The 440s have harden seat heads there 213 a high temp head. The 400 has 452 harden seat heads.
All engines come with flex plates and bolts. The 400 has the new flex plate so you can run natural balance torque converter.
The 440 are $5000 each and 400 $4000
The engine are located in OHIO 44826
ID pad j440T 7-18 2
ID pad j440T 2-2 2
ID pad 7T400 9 8 E
