Building up my 46re for my jeep.
-I have 5 direct clutches going in
-Using all 15 springs
-Will set clearance of clutches at .060 - .075 (.010 - .015 per clutch)
-Get ride of the the wave snap ring and replace with desired thickness flat style
-Sonnax billet front cover
-Sonnax acumulator (no blocker rod) with the big outer spring only
-billet rear servo (shift super servo?) with HD spring and billet spring retainer and shimmed solid.
-HD band sturt
-Billet band anchor wedge
-front brass impregnated flex band
-rear red with oil grooving
-3.8 or 4.2 billet lever???
-tfod-3 transgo kit to make valve body full manual so I can run it without a computer
-orfice installed and tuned to clear up flare shift.
Now, can I add two springs to the sonnax front servo like they did on the old 727 to help with 2-3 flare?
Will a 3.8 lever out of my old 727 be better then the 4.2? Will the non billet hold to higher line pressure??
This is behind my 360 la block with EFI...around 420hp - 500 lbs torque (all estimated/calculated) No dyno numbers.
4.56 gearing, 39.5" tires. This gets abused. First gear will see 5,500 rpm up hill climbs in 4 low.
I would love to run a rigid front band, I just can't afford to spend $125 on that rite now. I have used the flex in the past and they worked out really well for me with no wear.
-HD band sturt
