46rh od and LU wiring
mbaird
mbaird
Boise, Id
Which of the 3 pins on the trany is LU and which is OD ?
I have found diagrams but they don’t indicate the orientation of the plug … is the pin closest to the front the lockup ?
Thanks
Thanks .. it’s hard to tell if that diagram is from top down or bottom up. Just want to make sure before soldering and assembling the plug .
I have found several different techniques for controlling the OD and LU . One uses 2 pressure switches and another uses one . I chose to go the simpler route using 1 switch and 2 timers . But I also read that it might be bad to have both disengage simultaneously? Why is that a problem?
Here is the diagram I am using
Imagine you have 4:10 gears.
This is fine on the hiway with OD and lockup but,,,what happens when both disengage?
ZING!!!
True but that would be an extreme example. I suppose if your doing 80 and floor it enough to drop to 3rd there would be a significant rpm spike but I don’t see myself doing that.
Funny thing is that is exactly what my 2003 Ram does . I hate the programming on that trany ! It will bog when I accelerate at hiway speeds until the pedal is almost floored ! Then it disengages the LU and OD while simultaneously downshifting all the way to third . Then it quickly starts shifting up , re-engaging od , then lockup then starts to bog again .
Climbing mtn passes or even moderate uphill are so annoying!
I intentionally did not install the throttle disengage for that exact reason.
It takes a very steep grade for that to be needed in the car.
If I need to accelerate that hard I just turn OD/and or lockup manually, then set it back to fully automatic after.
I guess I am asking if it could damage the transmission ? Or just over rev the engine ?
