46rh pump gear teeth
Josshh70
Active Member
Lapeer, MI
so I was just wondering what the difference between the 14t and the 10t pump gears are. I pulled my front pump apart and found a 14t it will be going back into a GAS engine application. The reason for replacing is it’s wore out pretty good and has a nice wear divet on the tab the converter locks into
