What is recommended for a 10.5:1 470 street motor (625-650hp) on pump gas? I was thinking adding the OEM water pump housing, 180-185 T-stat, Proform electric water pump, and summit 27x19 radiator.
The OEM pump housing needs to be cleaned and painted or is better to get a alumuim? I was thinking of the Hughes (PRW housing) and new CRV 30gph electric pump from summit.
Will a stock pump support this motor? Its cheaper...
I have read may post but cant find a clear answer to what to run.
Thanks
Thanks
