Don’t know.
Slide in a cam, pair of lifters, pair of valves with checking springs, and pushrod length finder on each valve and see if it hits in the pushrod hole in the head (rotate the cam all the way through the lift events). Then see how bad your valve geometry/contact pattern is (or isn’t). You’ll need all of those things to assemble anyway. Head gasket or not, you’ll get close enough to have a rough idea.
