48 degree cams
Moparpuller
Fort Madison Iowa
I’m in the process of buying an r3 block. I have found a new 59 degree and a used 48 degree with w2 heads. Would much rather have the 48 but wasn’t sure of availability on 48 degree cams. Are cores available and who would be the best place to call? Thanks grant
It all depends on the journal size...50mm cores, I think Comp has some. 60mm Comp has a few, and so does Ritter.
