mguner
How many is too many?
I'm still accumulating some pieces for a Stealth headed 0.030 over 440 with a 4.125 steel crank. I was going the cheap route with some stock 400 cast pistons and just bore it 0.020 but Summit had a great deal on some Icon forged that would bring me a little more compression and reliability. So now I'm also on the hook for some new H beam rods with 0.990 pin size... I was wondering if any of you had dyno numbers from similar projects with flat tappet cams. 440 Source pushes the Comp Cams duration 295/307, lift .564/.564 hydraulic which would be close to 0.600 with 1.6 rockers. I have adjustable rockers and push rods and can go solid also. Compression should still be around 9.7 or so depending on chamber volume. It is a street strip application.
