[SOLD] 4spd trany with o/d trades
What would it take for this to work in an A body?
Either swapping in an A body tail shaft and tail housing or relocating the shifter location in the car.
Would a taillshaft from a 3 speed work?
So if I have a 1968 B-Body 833 and an A-body 3 speed I can switch tail shafts and it will locate the shift plate in the proper location for the 4-speed shifter?
The tail shaft housing will interchange, but I am not sure about the output shaft. I think the three speed is different from a 4 speed. I could be mistaken.
That would be correct Bobby. The A body mainshaft is shorter.
