Looking to see if anyone has engine mount brackets from a 75 and up 4x4 big block truck/RamCharger.
The driver side bracket is what I’m really after, because it’d be a lot harder to fabricate than the passenger side. But if you have both I might be interested.
Mancini and Bouchillon both have a kit that would work, but I don’t want to pay $250 for some bent metal that I could probably make on a bench vice.
2wd truck brackets will not work.
Thanks, Craig.
Thanks, Craig.
