[Found!] 4x4 truck RB Engine mount brackets
Craig Burriss
Statesboro Georgia
Looking to see if anyone has engine mount brackets from a 75 and up 4x4 big block truck/RamCharger.
The driver side bracket is what I’m really after, because it’d be a lot harder to fabricate than the passenger side. But if you have both I might be interested.
Mancini and Bouchillon both have a kit that would work, but I don’t want to pay $250 for some bent metal that I could probably make on a bench vice.
2wd truck brackets will not work.
Thanks, Craig.
Looking to see if anyone has engine mount brackets from a 72 and up 4x4 big block truck/RamCharger.
Thanks, Craig.
View attachment 1715854073 View attachment 1715854074 View attachment 1715854075 View attachment 1715854076
Are the pictures 4x4
I’ll have em $120 plus shipping
Tim@52537
72-74 has a divorced 205 transfer case and uses the same mounts as 72-up 2wd. 75-up has a married 203 transfer case and uses the mounts that you show.
