RussDavis
Putting a 05 5.7 hemi in my 73 Duster. Stock motor with a tune. Built 727 shift kit. Gearing to be 3:55-3:91. 275-60-15 tires. Its only for street use and some play at the strip. What stall would be best ??
Glad to see you're getting back on your feet, Russ.Putting a 05 5.7 hemi in my 73 Duster. Stock motor with a tune. Built 727 shift kit. Gearing to be 3:55-3:91. 275-60-15 tires. Its only for street use and some play at the strip. What stall would be best ??
FYI there is a .060" difference in depth between a 727 transmission and the RFE545 that comes behind the modern hemi.
Some 727 will bolt up just fine, while other require shim or spacer between the bell-housing and block. To bolt up a A833 you simply trim the end of the input shaft slightly. A number of companies sell a version of the spacer.
http://www.xvmotorsports.com/products/detail/index.cfm?nPID=207&cid=18&cdesc=Driveline
http://bouchillonperformance.com/61LHemi.asp
http://www.hotrodlane.cc/New HEMI Tech/65plymouth.pdf
Regards,
Joe Dokes
JD - would you know if the 6.1 needs the spacer to bolt to a 727?
I went with a custom PTC... Mine bolted right in place with no spacer needed, don't waste ur money. Also just make sure u use the Mopar flex plate and u will be golden pony boy!
