5.7 Hemi cam regrind
Any of the cam outfits can grind what you need. Lots cheaper and just as good as grinding a new core.
Billet cams are good but there have been a couple billion cast cams in use for the last 120 years that seem to do ok. If you have the $$$ to spend ok but it's not really needed.
its a roller cam engine. needs a good core not a regrind.
comp has shelf cams worth 100+rwhp on 5.7s and others.
They all need good cams....if you need a lot of spring pressure a billet cam may be in order. Otherwise a cast core is fine.
I would bet Comp sells more cast core cams than billets...
