5.7 injector flow rating
joeboy
Denver, CO
I'm making progress towards a start up... I've found conflicting info and thought you guys would be dialed in... 5.7 hemi from 2005 car, what is the flow rating on the factory fuel injectors at 58 psi?
26lbs? 30lbs? 32lbs?
Thanks in advance
Joe
I'd have to double check what I have mine set at on my Megasquirt, but I was pretty sure the stockers were in the 24-26 region. Pretty sure I had mine set at 24, but might be a little off.
