74SwingerSpe
Hi everyone,
We are installing a 2000 5.9 in our 73 duster project and want to keep the serpentine belt system and stock accessories. If we use the stock compressor, is there any options/adapters available so that we don't have to modify the stock a/c lines that connect to the compressor. The one piece connection is similar to old GM compressors, but just different enough that Vintage Air adapters won't work. I know I could take the stock lines and cut off the ends, opposite of the compressor connection, and then have additional pipe and new ends crimped on. However, I think it would be much cleaner to run new (separate) lines from the compressor. Has anyone else done this? Any help or suggestions would be appreciated.
Travis
Travis
