I have for sale a used 500-Watt Halogen portable flood light. It works perfectly with no issues. Here are some points taken off of a website:
Plugs into Standard 120 Volt Outlet
Bright, Natural White Light
500-Watt Halogen Bulb that provides 9500 Lumens of Directionally controlled Natural White light
Use 500 Watt or Smaller type T3 Bulb
Easy Tote Handle with Comfortable Foam Grip
Heavy Duty, Light Weight Direct Aluminum Housing
Adjustable Lamp Head for Greater Flexibility of Beam Direction
Sturdy Steel Tubing Base
Fully Weatherproof / Suitable for Wet Locations
Hinged Door Provides Tight Positive Seal Against Elements While Allowing Convenient
access for Bulb Replacement
Heavy Gauge Steel Guard Protects Against Rough Handling
UL Listed
I would like to get $8.00 for this lamp plus the shipping.
Ken
Edison, NJ
UL Listed
Ken
Edison, NJ
