6 and small block parts
earthmover
in the tire smoke
nc
6cylinder parts and small block
1. 73 motor mounts in good shape for 6 25.00
2. holley carb off 6 worked when removed 50.00
3.air cleaner of 6 that was on the holley 25.00 make a deal on carb and cleaner
4.170 head worked when pulled 50.00
5.170 block ran fine 50.00
6.170 crank 50.00
7.small block single plan holley intake 75.00
8.j heads that was on my small block before went 7.50 car needed some more chasiss work ,good springs for 555 cam $500.00
9.starter off the 170 work great 20.00
10.comp cam 501 hyd. new never used 75.00
got a few more parts gotta get to the shop and see whats out there just ask i my have it...​
68/69 340 deep pan,mp purple cam,hi comp. pistons,ebrook intake, j-heads,complete ***. needs rebuild and carb 2000.00​
also have a set of small bolt patt. drum and hub of my 70 duster 50.00
587 stock heads 50.00
have a set of small bolt patt. drum and hub thats been drilled to big bolt patt..125.00 still on the carwill be removeing soon..
also have a radi out of my old ebody was in great shape when removed has the tag still on it from the factory...65.00
1
[/LEFT]
will trade this parts for big block parts ...except the 340 motor that belongs to a buddy..
if not gone soon will go to the junk yard
the cam is still in the box it came in never been in a motor ....i got it about 8yrs ago i guess was going in my 360 but went soild instead..its a comp cam hyd. 292 with 501/501 cam thats comparewd to mopar 292 purple shaft....
the holley carb is off the 6 where do i find the 1920 # on the carb??? ill be glad to look and se..
hey stroker i feel yea but like you its not a hreat its going to be gone out of my way..i dont need it and thought i would offer it cheap i thought, but i guess its still to high lol..the juck man will give me gas money for it...ill even take some trades for this stuff....im looking some big block stuff or small block just dont need the 6 mike
